Zum Hauptinhalt wechseln
Aufpolierte Version des iPhone 3GS mit schnelleren Verarbeitungsgeschwindigkeit. Die Reparatur geht ähnlich wie beim 3G vonstatten und braucht nur einfache Schraubendreher und Hebelwerkzeuge. Modell A1303 mit 16 oder 32 GB Kapazität mit schwarzer oder weißer Kunststoffrückseite.
1500 Fragen Alle anzeigen
Why wont my iPhone recognize any charger?
my iPhone received water damage last night. it worked fine but wont connect to any charger and now that the charge is gone the phone is nothing more than a paperweight. i was wondering which part you think is damaged. im hearing battery, dock connector, and fuse on the logic board. i personally think its the connector but id like to get a more experienced persons opinion before i end up buying all three to find out that the last thing i bought is what was the problem.
it will not charge on anything and itunes doesn't recognize it. what do you think?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
I really don't mean to chime in here. But there is no way to attach an image to a comment, that is why I am posting this as an answer. I am now going on the assumption that you followed the advise of pollytintop and Richdave. i.e.replacing your dock connector as well as your battery. There have been issues with the batteries and a lot of people have had to replace them multiple times until they got a good working one. Anyhow the only other thing that I would suggest is that you check the two fuses on your iPhone. I am talking about the charging and the battery fuse. Use a multimeter to check for continuity.
War diese Antwort hilfreich?
Bewertung 6
3 Kommentare:
oldturkey you are answering,not commenting and not "chiming" in! it's a good answer too.. I think it's the next logical step if nothing else has worked. +
von
I just feel that the OP may get all confused if I start throwing more stuff in there. I know that you and Richdave were going in that direction as well, that is why I prefer to hang back and try to comment to elicit more information. Some of the info usually gets missed in the original question. You know the usual "Oh, by the way ...." ;-) I appreciate your kindness, as always. :-)
von
mine did the exact same thing, what i did was open up my phone through the screen. then i cleaned all the numbers under the screen with the connecters with a cotton swab. put it back together plugged it and it started chargeing.
von
it may be a faulty dock connector. Inspect the dock connector closely and see if there are signs of damage, corrosion or missing pins etc.
You should take a look at THIS guide too
Also check out this tool: iPhone 3GS Dock Connector
iPhone 3GS Dock Connector Bild
Produkt
$19.99
Bewertung 3
11 Kommentare:
if your talking about the cable, thats not the problem, i have tried it with two docks, the charger connected to the wall, and the charger connected to the computer. itunes wont even recognize it. i came in from the rain, cleaned it off, and the next morning it was at 40% im just wondering which part i need to replace
von
steve... look at the liquid repair guide..try cleaning the phone, you'd be surprised at what can be done by cleaning and without spending money on parts. It's a tricky call.. most damage is usually to the battery because we naturally place the phone on it's back to dry (where the battery is)...so it tends to corrode contacts etc. itunes will not recognise a phone if the battery is too dead. BUT both these symptoms may be the dock connector itself. So clean the phone, if the battery looks ok (you'll need to lift the motherboard out to see the entire battery connections) then clean the dock +++ and see if that helps.
von
@pollytintop i opened the phone. the battery has blue markings on it and all was dried out. i don't know if thats a sign of water damage. when i woke up and the phone wouldn't charge i plugged it into itunes at lets say 35% so itunes wouldn't read it when it had power. when i plug it into the dock i get a "charge the battery" symbol everything in the phone looked normal, but then again i don't really know in detail what an iphone is supposed to look like. now that its back together nothing much has changed
von
if it helps i only had it in the rain. light rain not heavy. but it was a good 20-25 minutes that it got rained on. im amazed because ive done this before and nothing bad has come of it. i WAS talking on it.
von
did you look at the link? iphone's have a white sticker that turns pink if there is moisture inside the phone ..the 2 stickers are on top of the motherboard shield(they don't change back to white when it dries out!)clean the dock connector and see what happens
von
6 weitere Kommentare anzeigen
see if it charges turned off after it the "this accessory may not be supported" message appears.
It happened to me and I changed both,the battery and the port but it didn't change anything
Bewertung 0
I have no answers but still looking for answers. I have had my iPhone 6 a long time and I was having trouble charging on my car charger. I noticed this happen after the iPhone updates. I have recently installed a new battery and went to my Verizon store and purchased a charger that they said was compatible with my iPhone. I keep getting a message when I connect to the new car charger on my screen stating: “It does not recognize this device”. I went back to my Verizon and they checked the charger and said it is working. They were of no help other then their response was to call the manufacture of the devise I purchased from my Verizon store and see if they will replace it. My iPhone 6 seems to take a charge from the car charger in question but it takes hours before it show any type of a charge increase. I there any solution to this problem that I have seen in many post on the Internet, but no real good answers.
Wildman GM
Bewertung 0
Antwort hinzufügen
steven vitale wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 21,488
