Zum Hauptinhalt wechseln
Der iRobot Roomba 655 Pet Series Saugroboter, hergestellt im Jahr 2012. Exklusiv bei Costco erhältlich.
My side brush will not stay screwed in during use...why?
This happens on a daily basis, the screws used are supplied by the vendor.
It started when I noticed one of the 3 brushes had been 90 percent torn off.
I replaced the brush assy, screwed it back on, but I kept finding it and the screw unattached in the house. Its like the socket is stripped. Whats a gal to do?
Also…
The entire front wheel assy will easily drop out of the bottom of my Roomba, even if I pick it up! Why is this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
I wrapped teflon tape around the screw and it seems to be staying in for now.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
That works too!
von
Hilfreichste Antwort
If Roomba won’t help you, coat the screws with
Loctite Heavy Duty Threadlocker to hold them in place
https://www.amazon.com/Loctite-Heavy-Dut...
Bewertung 6
4 Kommentare:
@mayer - I would just use fingernail polish ;-}
I find the Red Loctite can be a bit too strong so you can't take the screws out later. Low Strength (Purple) or Medium Strength (Blue) maybe better choices.
von
@danj I like the Red on larger screws and the blue on small computer screws. The checkout guy looks at me funny when I buy nail polish.
von
@mayer - Just tell the counter guy its for your dogs nails ;-}
I personally use clear for by screws ;-}
von
Blue loctite doesnt work for me
von
Sounds like your unit is either defective or encounters a lot of vibration so the screws don’t stay secured.
I would recommend you speak with Roomba directly to see if they are aware of the screws loosing up as well as get the missing bracket and screws for your front wheels. Depending on when you bought the unit they may exchange it.
iRobot
Bewertung 2
The replacement brushes we got won’t fasten to the white bracket. Feels like screw is too short or the plastic threads are stripped.
Bewertung 0
I put a little piece of dental floss in the screw hole. When replaced the brush, the screw tightened firmly and the brush worked fine.
Bewertung 0
Antwort hinzufügen
Jeanne Stilley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 75
Insgesamt: 11,589
