Zum Hauptinhalt wechseln
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
78 Fragen Alle anzeigen
My calculator doesn't turn on anymore
My calculator stopped working out of no where. It doesn’t turn on no matter what I do. When i plug it in the orange light indicates it is charging. It will turn green after a while indicating it is fully charged. But when i plug it out and plug it in immidiatly after it goes through the same process again. It just doesn’s seem to charge. Does anyone know if there is a fix for this problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
Edit: It also doesn't get rocognised in the TI connect software when i plug it in to my pc.
von
I have this problem too. But the first thing that happened was that I fried the transistor that controls the LED, which I soldered off. But now after 3/4 months of giving it life support the thing doesn't want to turn on or charge anymore.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi, thanks for including all that information! I think TI-84 Plus CE Recovery Techniques. is what you’re looking for. Please comment if you still can’t get it working and I’ll keep trying to help!
P.S. The charging light is separate from the main calculator software so it can still charge even when the main calculator is frozen or broken.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
sorry for the late reaction but i did all of the above but it still doesnt work
von
Well that's surprising, even trying the OS reinstall didn't work? Were you able to get the display to even turn on for a second? This may be a display issue. I know you said you tried this before, but since you did some of those recovery techniques, something may have changed. If you plug your calculator into your computer, does your computer recognize that something was connected? If so, then it's most likely your display that's broken. Let me know if you think that's your problem. If your computer doesn't recognize that something was connected, then you've got hardware damage. You can try to take it apart by using a teardown guide ( TI-84 Plus CE Teardown ) however if your calculator is still under warranty, I would highly suggest turning to TI customer support and requesting a new calculator instead: https://education.ti.com/en/customer-sup...
von
Antwort hinzufügen
Martijn Wobbes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 840
