Zum Hauptinhalt wechseln
The Acer Extensa 4630z is a laptop computer introduced by Acer in 2008. The Acer Extensa series is a line of Acer laptops designed for business and office users.
4 Fragen Alle anzeigen
Why is the display not working after I reinstalled the RAM?
I removed and reinstalled the RAM and HDD and powered my laptop and it ceases to display anything. As a matter of fact it was working properly before but was crashing during Windows Xp loading with BSOD, Now the laptop powers on but no display whatsoever.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
@huracanevo are there multiple memory module installed?
test with one stick at a time
von
I only have single RAM but two DIMM
slots
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It is seem to be only some boot hardware failure. Do you get any system beep sound when you power on laptop. Do one thing. Only install RAM in same slot where it was working before. Do not install HDD. Now power on laptop. Also inform any LED on display turn on or now.
I think ram is not properly installed or hdd is not properly fixed. Inform us what is system sound or beep sound when turn on.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
There are no beeping hardware internally installed .... there are LEDs indicating HDD ........ I will give it a try
von
Display should work no matter HDD is installed or not ,right Its just the RAM that display is affected
von
Did it and no sign of display working..........But the first time I press power button it powers up ...shuts down for a while and then powers up again......What is the cause?
von
Hilfreichste Antwort
The ram may not be seated in fully or dust is inside the ram slot. Make sure they are seated in well.
Bewertung 1
3 Kommentare:
No I did it multiple times but the results are same
von
Hi @huracanevo ,
You didn't leave the battery in when you removed / replaced the RAM and HDD did you?
Try a power reset,
remove battery (and charger if inserted) press and hold Power button for 20-30 seconds then release.
Insert charger and switch on charger (leave battery out)
Assuming RAM at least is installed, turn on laptop and check if display works.
von
I actually went through Youtube videos that said static could be the cause of display not working......I did that multiple times as well ...no luck
von
Antwort hinzufügen
Namaste Holiday wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 318
