Zum Hauptinhalt wechseln
Die Sony Cyber-shot DSC-W830 ist eine 20,1-Megapixel-Kamera, die für die Aufnahme von Fotos und Videos mit bis zu 720 Pixeln entwickelt wurde.
How to fix error C:13:01? re-insert memory card?
I have sony DSC-W380, then suddenly after using cannot open file. the image was C:13:01, re insert memory card. how to fix it?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
I had the SAME PROBLEM! On the SAME CAMERA! I need to know this answer ASAP. I re inserted the memory card and that didn't work. I tried another card, that didn't work.
von
Einen Kommentar hinzufügen
1 Antwort
I had this error about five years ago in a  Cybershot camera.  The error seemed to be caused by a bad contact  between the camera and the memory stick.
I gave the camera's slot a blast  of compressed air, cleaned the contacts of Camera & Memory Card and inserted &removed the  memory card several times in quick succession.
And this solved the issue.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
I already did but its the same, no changes. =(
von
If there is no important data on it, try to format it using PC/laptop
von
cannot also detect on PC/Laptop. yes it has important data.
von
Antwort hinzufügen
Joefine wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 30
Insgesamt: 4,378
