Huge "APFS Volume VM" - How Can I Resize?
I took out an old 240GB SanDisk SSD to use in an enclosure as my Time Machine backup. I reformatted to APFS and wow!
The “APFS Volume VM” is 17.2GB! No success making it smaller.
Suggestions and ideas please.
Thank You,
Carl
/dev/disk4 (external, physical):
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *240.1 GB disk4
1: EFI EFI 209.7 MB disk4s1
2: Apple_APFS Container disk5 239.8 GB disk4s2
/dev/disk5 (synthesized):
0: APFS Container Scheme - +239.8 GB disk5
Physical Store disk4s2
1: APFS Volume Preboot 20.5 KB disk5s2
2: APFS Volume Recovery 20.5 KB disk5s3
3: APFS Volume VM 17.2 GB disk5s4
4: APFS Volume 240GB SSD 839.7 KB disk5s1
Ist dies eine gute Frage?
Did you have this setup as a Fusion Drive?
You appear to have quite a few volumes which you need to delete.
von Dan
Dan. You're incredible. Your plethora of responses makes iFixit. They'd be nuts not to hire you.
It wasn't a Fusion Drive. I installed my old MacBook Air blade into my iMac. That's now the boot drive. What you're seeing is from the backup SSD I was using to backup my Documents Folder on the new 1TB SSD I put in place of the old cruddy 1TB HDD. I have no idea how the backup SSD got so complicated. I pretty much gave up and fixed the problem by doing a hard wipe back to its original 240GB state. No more containers, volumes, etc.
Yet, the backup SSD is still filling up! But not quite as bad. This time only 13GB instead of the 17.2GB with what I can only assume to be Time Machine Backups.
So. How can I stop Time Machine from backing up to my system because I have a Time Capsule! I thought everything would just go onto the Time Capsule. Doesn't that make more sense or is this a backup of a backup on my external backup SSD?
Thank you,
Carl
von Carl
