Zum Hauptinhalt wechseln
Modell A1311 / Ende 2011 / 3,1 GHz Core i3 Prozessor / Nur für Bildungseinrichtungen
What cpu and graphics card are compatible with this iMac?
Hello, i have a emc2496edu imac and it has a dual core i3 with 256mb AMD Radeon HD 6750M is there a compatible graphics card and cpu for this upgrade? i would 4 cores and and at least a 1gb graphics card. and also is there a firmware patch i can use to get mac os mojave to run on it?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
So what should i do at this point? Should i replace the logic board with a late 21.5inch 2012 imac logic board? Would that Even work? Or should I just sell my imac and put the money towards a new one?
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
As I stated in your other question figure out how much you are willing to put into this system. I would focus on the CPU, RAM and If you can Storage (SSD). Also consider what you are planning on using your system for.
von Teilen
Hi Zachary,
The best option is to find some replacement parts pulled from old iMacs, though upgrading CPU to run Mojave, isn’t possible. Too many power draw issues.
Bewertung 0
1 Kommentar:
@iphonerepairman - Tim, There are solutions here without going that far.
von Teilen
Zachary - You should go back to your original question as the answer is there as far as upgrading your system. You can install either a i5 or i7 CPU. What cpu can I upgrade my iMac to?
As far as sliding in a 2012 logic board, sorry thats not possible! Apple altered the 21.5 system design quite radically in 2012.
An alternative to upgrading the CPU & GPU board is to replace the full logic board with the 2011 21.5” iMac with either a i5 or i7 logic board within this series iMac12,1
Bewertung 0
Antwort hinzufügen
Zachary Schwanke wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 1,578
