Zum Hauptinhalt wechseln
The K56CM is a 15.6-inch "ultrabook" laptop manufactured by Asus. It was first announced in 2012.
5 Fragen Alle anzeigen
PC does not recognize second hdd after restart
Hi
I upgraded SSD for my laptop (Asus K46CM) using caddy bay.
SSD is installed on caddy bay at location of DVD slot. Old HDD still stay at original HDD slot. SSD for Windows and HDD for Data store.
At first boot, PC recognized all device SSD and HDD.
I’ve installed Windows and it boot up normally. But after restart, my PC can not detect SSD at DVD slot and of course, PC can not boot to windows.
I’ve checked on BIOS at that time and found that PC recognize only old HDD.
I tried to shutdown PC by pressing power button and turn on. It work normally.
PC booted into Windows and I can access 2 disks without problem.
Summary:
Restart PC ==> Can not detect disk in caddy bay
Shutdown and turn on ==> Work properly.
Can someone help me to fix this issue ?
Thank you in advance
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Are you sure windows is installed on the SSD? Also make sure the SSD is the main and HDD is Slave. Change both hard drive by swapping them and try booting
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you Daniel for advice. I will try and feedback result.
von
It's work. Thanks so much Daniel.
von
Antwort hinzufügen
Anh Dinh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 429
