Zum Hauptinhalt wechseln
Das März 2015 Update von Apples 13" MacBook Pro Retina Display, Modell A1502, bietet fifth-generation Intel Core i5 und i7 Prozessoren der 5. Generation und führt den Force Touch Trackpad ein.
1185 Fragen Alle anzeigen
Replacing trackpad cable, any need to disconnect battery/logic board?
Based on answers here, I need to replace my trackpad cable. In the trackpad replacement iFixit guide, first steps are to remove battery cable and logic board cable. Since trackpad cable should run over the battery, and that is all I am replacing, do I need to remove the logic board and battery cables for any safety reasons, or can I just remove logic board cable cover and remove the trackpad cable? Thank you for your help.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Always disconnect the battery when working on electronics. If you drop something metal on the board then it's shorted somewhere, if a connector doesn't go in right it's shorted, if you tap something anywhere that's an exposed contact you risk shorting it. No matter how small you should always disconnect the battery and unplug the device you are working on to reduce the risk of damage.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
philyfan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 144
