Zum Hauptinhalt wechseln
2.0GHz, 2.3GHz, oder 2.6GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
580 Fragen Alle anzeigen
Installed new battery but system say battery required service
Installed new battery yesterday. System information say that battery required service and that the capacity is at 2108 mAh. I had discharge the battery and recharge to full again and the message is still the same.
Is the battery faulty or is there anything I can do to fix
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Sounds like yo got a defective battery contact Ifixit for a replacement.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Did you sync the battery after you installed it? If you didn’t that might be the problem.
Go to step 55 and follow the bullets at the end: MacBook Pro (15 Zoll, Ende 2013, Retina Display) Akku austauschen
War diese Antwort hilfreich?
Bewertung 1
Hi,
How many percent your battery when its shows service?
my suggestion just charge your battery into full and drain it, try that step 3 times
Bewertung 1
1 Kommentar:
Thank you rondel.
The problem is now fixed. I'd followed ifixit battery replacement step 55 to the dot and battery condition now normal with capacity of 8500+ mAH.
Thank you
von
Antwort hinzufügen
Mario Wong wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 51
