Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
I replaced the battery of my iPhone 5
I replaced the battery of my iphone 5 following the instructions in this site, and everything seemed okay until the end. But before closing the box I turned it on and it worked ok. But I can not close the box anymore, it looks like something is pushing up. The new battery is exactly the same thickness as the old one. Any help?
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare:
Can you put a picture on. I am assuming that you are not putting the screen in correctly.
von
Fortunately after I opened the iPhone to take the first picture, when I was closing it again, I tried to press carefully down, and it worked. It closed perfectly. Thank you all for your replies.
von
Einen Kommentar hinzufügen
1 Antwort
I just had this problem at the shop I work in. What I like to do is close everything and see which part of the screen is peeking up. There has to be something in the way or a panel is screwed in upside down. Also check the screen to see if theres anything blocking it
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
A lot of times it's the corners of the iPhone being dented in stopping the screen from going in on the corners.
Sometimes I bend these corners back to normal or put the screen in hooking from top, getting the bottom to fit in then the middle last.
von
Antwort hinzufügen
sergio barrozo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 47
