Zum Hauptinhalt wechseln
Designed by ASUS in 2015 as a budget laptop made for travel and everyday uses.
Charging port LED flashing green, won’t power on
I replaced my chromebooks LCD screen and now when I try to power on the chromebook the LED beside the charging port slowly flashes green (green for about 2 secs, off, green for 2 secs, off, etc).
Does anyone know what this means? I’m not sure if it signifies something I haven’t connected correctly when replacing the screen.
TIA
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare:
I had the same problem, mine won’t turn in and the battery light is flashing green. I took the battery out and plugged it in to the adapter. It is now flashing green then red, and the power button flashes white but it still won’t turn on. Does that mean my adapter isn’t working properly? I don’t understand why, it’s only a few months old.
von
Same,I am unsure.should I open up the chromebook? Tho it's an Samsung one
von
Einen Kommentar hinzufügen
1 Antwort
The flashing green LED usually indicates a charging problem. This could be the power adapter, motherboard, or battery.
Shut down the laptop, take the battery out, and try to start the laptop up with only the power adapter. If it doesn't start, you may have an adapter problem.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mark Naylor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 61
Insgesamt: 14,050
