remove cover with screen protector
Can I remove the phone cover with isclack or suction cup without removing the screen protector glass first?
Ist dies eine gute Frage?
if you are carefull enough then it is possible, when you have lift the front put some thin knife in the gape between front and housing at the bottom.
War diese Antwort hilfreich?
My preferred method would be to use the iSclack to get in-between the frame and the screen just enough to get a pick under the screen. Then use the pick to loosen the clips. Works every time even with screen protectors.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 49
