Zum Hauptinhalt wechseln
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
54 Fragen Alle anzeigen
Battery life after repasting
I have a 15” FHD dell xps 15 9560.
I upgraded the ssd to samsung 970 512gb
8gb ram to 16gb
& Repasted the pros & vga.
After doing so my battery life seems to be down to about 2/3 or 1/2 of what i had.
Battery condition is 100%
Do you think i did pasting wrong?
Any suggestions?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If you mean you cleaned the thermal grease off of the processor and gpu then if it was not done right it would lead to overheat conditions. You should run the Dell diagnostics, restart computer and press F12 to bring up the menu and select diagnostics. The SSD you installed may be the cause of the power change, diagnostics should help with that.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Corrected key to press for Diagnostics.
von
Antwort hinzufügen
Malith Gayan Hettiarachchi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 206
