Zum Hauptinhalt wechseln
HP Compaq 8100 Elite, Where is the Front Panel Connector?
I decided to build an all used parts PC and try to get bang for the buck performance. Well I have everything but the front panel done. I cannot find the front panel connector. The motherboard is powered because there is a green light on the motherboard. Any help would be appreciated! Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
Hi @imjimjim21
Your question is not clear and I would like to know more
So are you still using the existing HP 8100 mainboard or another mainboard?
How about the computer casing ? are you still using the HP or new casing?
von
@augustine Sorry about that, I am still using the HP 8100 Elite mainboard. For casing I am using the Corsair Carbide Spec-04 Tempered Glass. I have the board in the case and I looked up the orientation of what the front panel connectors go, but I do not know where to plug them in at:(.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hi Jimmy,
HP 8100 service manuals. The second one has a good photo. Zoom in and read the labels.
http://h10032.www1.hp.com/ctg/Manual/c02...
Page 7-8
and
http://h10032.www1.hp.com/ctg/Manual/c03...
To get the above all I did was search “HP 8100 Elite manuals”
War diese Antwort hilfreich?
Bewertung 4
I'm also having this problem with the 8100 elite I looked on Mike's first link and found out my motherboard is the 8100 elite ssf but when I look at mine P5 is the correct place
but on my actual board I have this
I have this?
7 by 2 minus 1 on the manual but only 5 by 2 minus 1 on the board. Any ideas.
Bewertung 0
2 Kommentare:
Could you do the photo again only this time in focus?
von
Hi, I have the same problem as you... have you solved it?
von
https://www.reddit.com/r/buildapc/commen...
Bewertung 0
Antwort hinzufügen
Jimmy Robertson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 4,282
