Zum Hauptinhalt wechseln
Abgesehen von der Tahoe Limited Edition wurde das Fahrzeug für das Modelljahr 2000 auf der neuen GMT800-Plattform neu gestaltet, die weiterhin mit den Pick-ups und SUVs in Originalgröße geteilt wurde.
brake pedal falls to floor
I have a 2003 Yukon denali. I have replaced front hub assemblies on both sides. both front calipers, hoses, rotors and pads. and also drivers side rear caliper. also replaced master cylinder. manually and electronically bled the brake system 10 or more times. if stitting at a traffic light after about 10 seconds the brake pedal falls to the floor slowly and the truck starts moving forward. what can cause  this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I changed brakes rotors and calipers brakes still not working
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
A “soft” brake pedal that goes all the way to the floor can be caused by a number of reasons.
  1. Low brake fluid – check for leaks underneath the car. ...
  2. Bad brake booster – this can cause longer stopping time. ...
  3. Failing master cylinder – this is usually the culprit if you're not losing brakefluid.
  4. https://www.youtube.com/watch?v=DzS4VOJw...
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
I agree with [ Mayer ]
I know this is an old post, but just in case anyone looks at it.
Always check for leaks first. You must check brake fluid level is not dropping. Only Then look for the other things like the Failing master cylinder, (internal seal failure). In my case I already replaced the master brake cylinder, so think I have a faulty ABS module itself ( faulty valves ), intermittently causing the pedal to go to the floor. It can also be caused by sticking calliper's. If a brake pad is moving away from the disk, then the pedal must travel further before the brakes go on. Also check your hand brake adjustment is correct.
von
Thanks just starting to have this problem
von
Antwort hinzufügen
lisa walker wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 22
Letzte 30 Tage: 70
Insgesamt: 12,565
