Zum Hauptinhalt wechseln
Modell A1502 / 2,6 GHz (Turbo Boost bis zu 3,1 GHz) oder 2,8 GHz (Turbo Boost bis zu 3,3 GHz) Dual-Core Intel Core i7 Prozessor mit 4MB geteiltem L3 Cache.
Is an A1502 early 2015 logic board compatible with an A1502 mid 2014?
I have an A1502 mid 2014 MacBook Pro 13inch Retina display.
I am interested in replacing my logic board with an upgraded one, which is from an A1502 early 2015 MacBook Pro.
Will that be compatible?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
It does not appear o be compatible:
MacBook Pro 13" Retina Display Late 2013
COMPATIBILITY
  • MacBook Pro 13" Retina A1502 Late 2013 to Mid 2014
  • (Early 2015) 2.7 GHz Logic Board
  • COMPATIBILITY
    • MacBook Pro 13" Retina A1502 Early 2015
War diese Antwort hilfreich?
Bewertung 3
There is some inconsistencies between the 2013, 2014, and 2015 models with regards to logic board compatibility.
Find your serial number and put it into the parts checker on powerbookmedic to be sure.
I was in a similar boat and had to double and triple check which logic boards were compatible before I bought one.
Powerbookmedic will give you specific parts numbers which you can search on ebay and elsewhere for replacements.
Bewertung 2
Antwort hinzufügen
Gao wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 586
