Zum Hauptinhalt wechseln
Introduced in late 1986, the Apple 3.5 drive was an external Double Density 800K floppy drive that could be used on most Apple Computer platforms of the time.
2 Fragen Alle anzeigen
Removing stuck yellow disk - Solved
Trying to repair 800k external drive, but yellow disk stuck in mechanism and stopping me from removal of sliding trays. Need suggestions to move so I can continue to finish the tear down.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
The eject mechanism will not move the disk. See the picture of the drive with partial tear down. The yellow disk just won’t move.
von
Ok problem solved. After a few more shots of penetrating PB the slide mechanism finally broke loose after 30 years of inactivity.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
This model does not have a tray that ejects (slides out). It just sucks the disk in. To eject an inserted disk, press the eject button to the right of the slot. You can also try holding down the mouse button during start up of the Mac it’s attached to.
Apple 3.5 Drive External Floppy Drive Teardown
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
GP Chanko wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 730
