Zum Hauptinhalt wechseln
4-Zoll iPhone herausgebracht im März 2016 mit ähnlicher Hardware und Spezifikationen wie das 6s. Erhältlich in Silber, Space Grau, Gold oder Roségold mit 16/64 GB Speicher. Modell A1662 und A1723.
1049 Fragen Alle anzeigen
iPhone se logicboard replacement
This board is from an se I have and I wanted to replace the broken parts that you see on the picture, I have another se board that’s exactly the same. Can I desoder the parts from that board and soder them back on to my se board. I’m still new at soldering but I’m planning on using mini soldering tweezers. Any advice would be much appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Thank you for the reply I took your advice and didn’t touch the board. I’ll probably just use it for practicing instead of trying to fix it. The board doesn’t boot up at all so once I read your advice I figured it was too much to invest in then just buying a new one. Thanks again
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
That is probably not a great plan—for now. Here’s why:
# If the board you intend to fix that is missing that row of caps doesn’t have anything else wrong with it, then it will likely boot right now without them. If it doesn’t, then you have bigger fish to fry.
# Mini soldering tweezers are not the right tool for the job because of the tight clearance. You’d end up making a bunch of solder bridges. A tool small enough to actually fit between the components would not be able to deliver enough heat to melt ground pads—-a catch 22
  1. The right tool for this job is a hot air rework station. To use hot air and work on THIS section of the board is fairly advanced. By the time you have the technical proficiency to successfully work that close the underfilled CPU, then you’d have enough experience to know the answer to this question :)
Microsoldering is really fun, I hope you give it a try. But this isn’t the project you want to start with.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
@jessabethany Boy do I need one of those Magic 8 balls! Do they make one for diagnosing Macs? Looks like Apple knows what a subversive you are to their infinite wisdom on data recovery. Keep up the good work ;-)
von
Antwort hinzufügen
Scott Sanchez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 73
