Zum Hauptinhalt wechseln
Anleitungen für Reparaturen im Haushalt, von Möbeln bis hin zum Klempnerarbeiten
3886 Fragen Alle anzeigen
On my a c. The Condenseing fan motor is putting voltage on the system
The Condenseing fan motor is putting voltage on the system it's a single phase 1/6 hp 208 to 230 v has a comparator and rotation wires. New motor and comparator with v meter touching the motor casing and ground I am getting 240v when I un plug rotation wiresthe v go away but motor will not turn
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
@arthurfrye44 sounds like you are describing a ground fault. what make and model is your AC?
von
Einen Kommentar hinzufügen
1 Antwort
You're not an electric wizard. Please don't die trying to fix this. 230 volts is powerful and lethal. Sounds as if you procured a general purpose replacement for the dead motor and now it's not going back together correctly. Look up schematic diagrams and connect the dots. If your new motor isn't the same as the old one, it can be made to work with labor and materials. If you mess around too much something will die. Then you will spend more money on it or get shocked or both. Find a schematic reader.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Arthur frye wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 48
