Zum Hauptinhalt wechseln
Die 2013er Neuauflage des Mac Desktops, bekannt als Mac Pro.
117 Fragen Alle anzeigen
Upper air seal broken
Hello,
Just now while cleaning my Late 2013 Mac Pro, the upper air seal that's in the shell of the cylinder partially disintegrated causing it to fall in half. Most of the strip is still there, but part of it is hanging down. I can still put the shell back on and manually guide the seal back against the shell as it closes. However, I am wondering if anyone knows where I can purchase a replacement seal that goes around the upper part of the cylinder shell?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Would you post a photo so we know exactly what you are talking about?
von
Here is a photo of inside the top of the exterior shell, this shows the seal I'm talking about. https://ibb.co/Xt1QmV4
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would use some B7000 adhesive and a pair of tweezers and reinsert it. I have no idea if this is sold as a separate part.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Using B7000 adhesive worked! Thanks!
von
Glad it worked for you ;-)
von
Antwort hinzufügen
Andrew wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 79
