Zum Hauptinhalt wechseln
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
How to increase how many time the phone rings
My phone only rings 4 times before going to message bank. How do I increase the amount of rings?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 11
1 Kommentar
Not able to select ring time function as there does not seem be one when i go to answerering set up. I have dect 1735 series 6.o
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
In standby mode go to Menu > Answering Setup > Ring Time and select either 2, 4 or 6 rings.
Credit to @jayeff for having answered this before.
How do I change the number of rings?
War diese Antwort hilfreich?
Bewertung 6
4 Kommentare:
Hi @ambientprotect ,
The answer in the link was for a phone just not ringing long enough before its' answering machine responds to the caller and not for a phone service which has a messagebank (voicemail) facility answering too soon
Thanks for the credit though ;-)
Cheers
von
Haha my bad @jayeff thanks for letting me know.
von
Not your bad at all. Looks like you were right as the answer was accepted by the OP.
It's just that I've never heard of a phone's answer machine recorded messages being called a "message bank", usually it is just referred to as "the recorded messages" or even "the phone messages".
Here "Messagebank" is a name used by one telco to describe its' Voicemail service.
Terminology, go figure ;-)
von
doesnt work that way i tried
von
Hi,
If your incoming phone calls go to Messagebank (Voicemail) too soon, you need to go to your landline phone service provider’s website (or call them) and search for how to extend the ringtime on your landline phone if you have a voicemail facility associated with the phone service.
Each service provider has their own code that you have to dial.
If your landline phone service is connected to Telstra Australia and has the Messagebank facility, here’s the procedure:
1: Pick up the phone and press * 99
2: Enter the number of seconds you wish the phone to ring before a call is diverted (between 5 and 60 seconds).
3: Press # and hang up.
Bewertung 2
1 Kommentar:
dont know hyave to call provider
von
Hi @Elli Christianson
According to the user manual (see p.20) the answering system ring time can be set for either 6, 9 or 12 rings before answering.
Bewertung 0
Antwort hinzufügen
newtrev69 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 18
Letzte 30 Tage: 88
Insgesamt: 34,370
