Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz) oder 2,5 GHz (Turbo Boost bis zu 3,7 GHz) Quad Core Intel Core i7 Prozessor mit 6MB geteiltem L3 Cache.
467 Fragen Alle anzeigen
Can I swap my Logic Board by another with Discrete GPU?
I’m thinking about making an upgrade to my Macbook, by replacing the logic board for another of the same year and model, but with a discrete GPU.
I imagine that i’ll have to replace the heat pipe aswell. Is there any other thing that I must take in account or is it impossible?
Thanks Gil
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There shouldn’t be any issue switching logic board. As long as it is the same year and size you will be fine. You will want to get one with a heat sink or purchase it separately.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
But I'll only know the size once I buy the new one... I'v already looked at the pictures of both, and seems similar but I can't guarantee
von
at least the mounting points seem the same.... but the battery connector seems different... probably will need a new battery pack
von
As far as size I am referencing the macbook model not logic board. You can put a mid 2014 15" macbook pro logic board of any type into a mid 2014 15" macbook pro. the battery will be the same, as will the mounting points. Manufacturers, especially apple, wouldn't make different cases for each logic board.
von
That's right, sometimes they replace just a couple connectors so as to make life more interesting in their view ;)
von
Antwort hinzufügen
gil.rodrigues wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 67
