Zum Hauptinhalt wechseln
Release date: Jan. 24, 2008; 8MP, 3x Optical Zoom, Built in optical image stabilizer system and Face Detection software; DIGIC III Image Processor.
13 Fragen Alle anzeigen
Suggested addition to repair instructions
When reassembling:
1) Be sure the ribbon cable from the LCD screen to the front of the camera is fully seated in the connector.
2) Before replacing the back cover, be sure the slide switch position is in the bottom position and so is the actuator on the back cover.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Gene, all of the guides are accessible to be changed by anyone. Just go to the guide you want to change and hit the "edit" link. Make the change you want and hit the "save". Later someone with a higher rating (and hopefully knowledge of the issue) will review you changes and approve or disapprove them. You get to be part of process and helping fix the world!
War diese Antwort hilfreich?
Bewertung 5
Antwort hinzufügen
Gene Arnold wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,268
