Zum Hauptinhalt wechseln
Traditioneller analoger Doppelglocken-Wecker von LaCrosse. 16,5 cm lang, 11,4 cm breit, 5,1 cm tief und 227 g schwer. Gehäuse aus goldfarbenem Metall, leuchtende Zeiger und Stundenpunkte, analoges Quarzwerk und Linse aus Klarglas.
Detached wires on analog twin bell clock
Hello,
my twin bell clock fell off the shelf and 3 wires got detached. Can anyone help me put them back into appropriate spots? There is one hanging from the bell part; another one from the battery piece, and the last one from the little compartment in the middle. Thanks for your help in advance.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Ania ZygZak  right now it looks like you are only supplying + to the clock. I would connect the wire marked with the green arrow to the clock mechanism. It is hard to see but it appears as if there was solder on the 2nd connector on the mechanism. See if that gets the clock going. I would need another view from the side (red arrows) to see if there are any solder pads and where the far right wire connects on the bell motor. there appears to be some writing on the mechanism any chance you can let us know what it says. I suspect a maker and model number which might help
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Ania ZygZak wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 40
Insgesamt: 1,755
