Zum Hauptinhalt wechseln
Das Dell Latitude E6400 war Dells Standard-Business-Notebook mit 14,1 Zoll, das im August 2008 eingeführt wurde.
quietest fan or cooling system for this laptop?
i own a latitude e6400 that runs with the fan like crazy and im trying to find the best and most quiet fan available, or if theres nothing is there a way to cool my laptop down without it getting too hot
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @fegelein3290
Since you mentioned that the fan is running fast and noisy,
I would suggest you to do some stuffs.
  1. Consider opening up the laptop to clean up the heatsink and remove the dust stuck on the heatsink.
  2. If fan has worn out, take it out and order replacement, you can find replacement on ebay / aliexpress, etc
  3. re apply thermal paste
  4. if all has been done but it is still noisy, consider updating the laptop bios.
  5. check OS configuration, if certain app is causing it.
  6. if it has improved but would like to further cool the laptop, consider getting a laptop cooler pad, get reputable brands like coolermaster, etc.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
how do you know if the fan is worn out?
von Teilen
Hi @fegelein3290
Like it is spinning slowly, and if use finger to spin, you will find some resistance.
noises like grinding, etc
von Teilen
ok, I will check, but im not sure if its that bad, Im saying in total the entire laptop gets hot, so im looking for a fan thats more wuiet and is good at cooling
von Teilen
Antwort hinzufügen
Brayden S wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 600
