The map is not populating
My Magellan Maestro is not showing a map anymore. It is also not giving audio directions.
Ist dies eine gute Frage?
Hi,
What is the model number of your Magellan GPS?
Most Magellan units have a “reset” pinhole somewhere either on the side or the bottom edge of the device..
Try inserting a pin into the hole and check if you feel a pushbutton when you gently press down.
If you do, hold it operated for a few seconds and then release and then check if the device has been reset and is functioning correctly.
War diese Antwort hilfreich?
where is reset pin pinhole of 5320 LM
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 68
