Zum Hauptinhalt wechseln
Die Xbox One X (Modell 1787) ist die neueste leistungsstarke Spielekonsole von Microsoft, die die Xbox One S ablöst. Die Xbox One X wurde am 7. November 2017 veröffentlicht.
159 Fragen Alle anzeigen
Xbox wont turn on
When the power button is clicked, the noise beeps like it is turning on and then followed by a high pitched screech and then it will turn off shortly after. the tv shows nothing other than a trouble shoot page and occasionally nothing, I've tried, plugging and unplugging, factory resets and nothing works
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
ok so, i hate being the one to admit this… but this happened to me before, but i caused it. Does the sound (sound) like its coming from where the fan is? Like maybe a mechanical screech? If so, its the fan hitting something inside. What i had to do was remove the casing (dont do this unless youre ok with voiding your warranty) and kind of bend the metal around it back into its original position.
War diese Antwort hilfreich?
Bewertung 0
Your vents might need cleaning. You can use a Compressed Air Canister, or just a simple vacuum. That fixed close to the same issue on one of my Xbox 360s.
Bewertung 0
Antwort hinzufügen
Benjamin Vidjen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 540
