Zum Hauptinhalt wechseln
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
52 Fragen Alle anzeigen
Apple 2016/17 Apple Blade SSD 5GA 34+22 Pins NVMe Converter / adapter
Hi I am looking for a adapter that allows me to plug in a 2016/2017 non touch bar ssd drive to usb or usb-c to read and test drives externally. I cant find anything online
Ist dies eine gute Frage?
Bewertung 6
3 Kommentare
Did anyone ever find a solution. I’m having the exact same problem. The Apple 22 + 34 pin SSD used in the newer 13” Macbook Pro Fn models.
von
Did anyone ever find a solution. I’m also having same problem. Looking for an adapter for for Apple 22 + 34 pin SSD.
von
Same problem here. I'm searching thoroughly, but no luck yet. :-(
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
@porterk74 - Please review my answer here Access to files on SSD drive.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
@rmmorshedbk - Sadly, the market for anyone to make a case to hold the SSD is just not there. OWC would have been the only one to have offered one and I don't see anything on their web site.
Apple has moved on to fully soldered SSD drives in the newer models.
von
A little spendy at $60 USD. If it’s for a 128GB SSD then probably not worth it. Could find a comprable (size/performance) for less with greater aesthetics.
https://digitalintelligence.com/store/pr...
Bewertung 1
1 Kommentar:
How does this Tableau adapter connects to PC/Mac? Is it SATA, or USB?
von
Antwort hinzufügen
kirk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 33
Insgesamt: 5,089
