Zum Hauptinhalt wechseln
The Dell Chromebook 11 3180 is a cost-effective, student laptop that runs on the Chrome operating system. It was first released on Feb. 7th, 2017.
9 Fragen Alle anzeigen
Why is my dell chromebook 5190 2 in 1 not charging?
I’ve plugged my chromebook and the white light on the corner led light is on only while it’s plugged in but it is just a black screen and it’s been charging for 7 hours and won’t turn on and i’ve tried everything. holding power button, holding the power and reset button, turning up the brightness, etc.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
May be a faulty battery that isnt accepting the charger port, or it may be a damaged motherboard or the battery is burnt out completely. Try replacing the battery first.
War diese Antwort hilfreich?
Bewertung 0
You’ve probably figured this out already, but here’s for the late-viewers. The Chromebook power shorted out on it. What you need to do is unplug the battery, and plug it back in. And then plug in the power cord, and it should start charging. We have this issue at my High School, I help fix every Chromebook that comes in.
Bewertung 0
Well if you bended your charger to plug in your computer and if you kept on doing that it would break the inside of your computer so you couldnt charge it.
Bewertung 0
Antwort hinzufügen
Genah L wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 1,244
