Zum Hauptinhalt wechseln
Das iPhone 6 Plus mit dem 5,5 Zoll Display ist die größere Version des iPhone 6 und seit dem 19. September 2014 auf dem Markt.
1525 Fragen Alle anzeigen
iPhone 6 Plus Error 4013 after Screen, Logic, and Lightning replaced
I recently gained possession of an iPhone 6 Plus that I replaced the screen on for a friend. The phone then proceeded to boot loop until it ran out of power. Thinking that the device was fubar, he gave it to me. So I decided to try basically everything. Got to the point that I decided to replace the logic board after having heard that error 4013 can be NAND related. Did that. Still get the exact same error whenever I try to restore it with iTunes.
64GB AT&T Locked iPhone 6 Plus
Parts replaced:
  • Screen
  • Lightning and audio assembly
  • Logic Board
  • 5GHz wireless antenna
Any insight?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
disconnect everything except chargeport and see if it will flash without errors, then if it goes through ok start connecting each component one at a time until you find the culprit.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
well... seems like the screen was the problem, but that raises a new question... how come a screen that was purchased from iFixit didn't let the phone boot or restore...
von
So, that "fixed" it, but now it just boot loops forever again... And I can't test the original screen anymore because it was practically unusable when I replaced it.
von
Bad front camera or home button flex from a screen that has preassembled components can cause this.
von
That is Nand issues,Most of the cases you have to reprogram Nand with removing from logic board and reprogram with programmer.
Bewertung 0
1 Kommentar:
The logic board has already been replaced with a known good board. So the issue is no longer NAND related. Also, I was able to get it restored by taking the replaced screen off. So the issue is now with the screen and that it causes a boot loop whenever it’s connected.
von
Antwort hinzufügen
John Peters wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 75
