Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz) oder 2,5 GHz (Turbo Boost bis zu 3,7 GHz) Quad Core Intel Core i7 Prozessor mit 6MB geteiltem L3 Cache.
467 Fragen Alle anzeigen
Can I add discrete graphics to Mid 2014 MacBook Pro
Hi I have a retina macbook Mid 2014 with intel Iris graphics and wondered if I could add discrete graphics to it as an upgrade?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
There’s no way to do that.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
This series came in two different configurations:
Intergrated Graphics
Dedicated Graphics
The logic boards are physically different! You can't add the GPU chip. You can only swap out the logic board which would be expensive!
von
Thanks Dan - that answers my question
von
If it was the 2016 or newer model with Thunderbolt 3 ports, I would have advised you to research the possibility of using an eGPU. I don't believe this is available for the model you have.
Bewertung 0
1 Kommentar:
There are a few eGPU systems which work via Thunderbolt-2. At this point it would be a used unit.
von
Antwort hinzufügen
Jeffers De Maio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 264
