Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
My iPhone screen is dark but work by seeing under a bright light
While I was uploading 3 of the apps at the same time, the screen went black . My phone screen is dark and the only way I can see anything is with a flashlight. Battery life is good. The touch is working. I can answer calls and do everything I normally do on my phone as long as I'm using a flashlight to brighten the screen. Even I can check my emails, can took pictures, can reset everything in the phone by using a strong flash light. The phone is in perfect condition, there's absolutely no physical damage to it and I have never dropped it in water. I have dropped the phone here and there but always with a case on it so there has never been any physical damage. I did the hard reset, factory reset nothing working to get back the bright screen. So far my phone is working normal, only the back light seems to be gone.
Does the LCD screen replacement will solve the problem?
Or
Is it a problem with motherboard so, I may not able to recover normal bright screen of the phone even replacing the LCD screen?
Thanks a lot in advance.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
—-NO
—-YES
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks a lot for being specific.
von
Hilfreichste Antwort
If it's happened out of the blue with no previous damage it would most likely be the backlight circuit, or some part of it. This isn't really a DIY repair, u will need someone who can microsolder and is capable of repairing the backlight for u a good repairer would obviously try a working screen for u first before doing any work to rule out the screen
Bewertung 2
2 Kommentare:
Thank you so much for the details.
von
It's really helpful!
von
Antwort hinzufügen
Nelufa wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 661
