Zum Hauptinhalt wechseln
Released on February 2016, The Asus Chromebook C202 is a ruggedized device created with students in mind. It is a small laptop that can handle minor spills and drops.
Device will charge not not boot
The device has all the power LEDs off, but when it plugs in only the charging light lights up. I’ve tried replacing the motherboard and the battery. Any suggestions?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
The motherboard to display cable was damaged.
War diese Antwort hilfreich?
Bewertung 1
Does your device have an hdmi port ? If so have you tried to attach it to a TV to see if your display electronics may be the issue?
Bewertung 0
1 Kommentar:
I found that it was the cable from the motherboard to the display was damaged.
von
Antwort hinzufügen
GanSolo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 291
