Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
Taptic/Vibration engine not working
Ok so long story short, the iphone got wet. They had changed the battery not long before but it seems they didn’t apply the glue well so it was cleaned inside and out. The first thing to go was the vibration motor, so i turned off, opened it and started the fix . i changed the taptic motor, lcd, and flex charge port. All works perfectly well in the phone except the vibration. i have already done everything (dfu, reset etc.) and still nothing. i haven’t still reseated the lcd until atleast i know what could it be. any ideas will be greatly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Since you already replaced the Taptic engine and the lightning connector, there’s nothing left except the logic board unfortunately. After liquid damage was the iPhone properly decontaminated ? If all it was done was a battery replacement you may expect other issues too down the road.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 105
