Zum Hauptinhalt wechseln
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
73 Fragen Alle anzeigen
Where is my camshaft position sensors on a 3.5 v6 ecoboost
I just can figure out where my camshaft sensors are on this motor
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
hillmatt26  looks like your engine has 4 variable camshaft timing solenoids ,
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
So how do I know which one is the intake and the exhaust? Is that related to bank 1 or bank 2 positions?
von
Hope this helps
Bewertung 3
4 Kommentare:
Are all the camshaft position sensors on this interchangeable? Why are my 2014 ford f-150 lariat ecoboost 3.5l camshaft position sensors is on the top rear of the heads?
von
This is where they are on the 2011 but all 3.5L ecoboosts year models use the same sensors. I provided the link to the ford parts website to purchase oem sensors and if you scroll down it gives you the list of compatible year models.
Intake part #du102
https://parts.ford.com/shop/en/us/electr...
Exhaust part #du90
von
After looking at this picture, I see I have two sensors on each side. TWO! Not one, but TWO! OMG. Code p054a refers to the camshaft sensor on Bank 2. Passenger side. Every video I ever watched everyone talks about 1 sensor. Replace 1 sensor. That's it. I need to replace both on the passenger side. I got a mirror to see exactly where it is. All videos refer to getting it off from the top. I actually saw a guy refer to pulling the tire and wheel well off. Wow, I just don't know. I responded to yours since it was posted this year. Thank you so much.
Any input on this from you would be greatly appreciated.
von
If you have 1 cam, 1 sensor on each side.
If you have two cams, 2 on each side / 2 for each cam
von
Is behind the driver side turbo charger
Bewertung 0
Antwort hinzufügen
hillmatt26 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 34
Letzte 7 Tage: 166
Letzte 30 Tage: 697
Insgesamt: 21,746
