Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2265 Fragen Alle anzeigen
Why is my iPhone stuck in 1% and restarting itself every few minutes?
So i wake up this morning and i dropped my iphone 7 from the bed, i went back to sleep and when i wake up my phone was on 1%,I tried charging it but it shows 3% or 5% and it restart itself every few minutes and the apple logo appears 2 times and it shows again 1%,the battery health shows "the iphone is unable to determine battery health", it was 84% before this happened.I tried to charge it after that and it go to 100% directly before to restart and when it restart it's again 1%.
i changed my screen 2 months ago.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hmm if you changed your screen, did you replace the plate over the battery? Open it up and disconnect and reconnect it. Maybe it just jostled apart during the fall. Try that, and let me know how it goes :)
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
it wasn't me who changed i took my phone to a repair shop. but i think that may be the problem.
von
Then yes, I would take it to the shop where you got the screen changed. Let them know the problem, and the suggested solution. I have ran across this problem many times at my shop.
von
thank you i will, i hope i don't have to change the battery .
von
No problem. Hopefully you don’t (:
von
Such problem accedentily happen by the following region.Actually that is related to SWI Line problem.
1- Battery must have problem.
2-Battery connector
3- Loose contact of battery to battery connector SWI line.
Battery have 3 pins,one is +ve,-ve & SWI.
On that cases if the problem still same after doing this you have to follow this process but remember need micro-soldering skills.
Bewertung 1
Antwort hinzufügen
lor mo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 46
Insgesamt: 1,482
