Zum Hauptinhalt wechseln
Hochleistungstablet der 2. Generation, herausgegeben von Apple im Juni 2017. Modell A1670
Ghost touch on top right side of screen
Bought a used ipad pro and thought I checked it out pretty well before purchase but not well or long enough apparently, (I've bought cracked iPads in the past with no issue so this took me by surprise and I'm wondering if the fact the ipad pro is more sensitive plays into it)
It has a small less than an inch crack in the top right corner which is where I think the ghost touch is coming from, it effects about one inch down and goes to the mid point of ipad, I normally throw up split screen and an app that it can play without distracting me from my work but I'm hoping to get it fixed soon
Wondering if this a digitizer issue, a wire issue, or a faulty processor?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
It’s the screen going bad. Is it a glass crack that you can feel by running a nail along it? If not it’s on the touch screen layer under the glass surface.
War diese Antwort hilfreich?
Bewertung 2
tow possibility
either the touch damaged and you will need to change it
either the touch ic damaged
and both need good skills to fix
Bewertung 0
Antwort hinzufügen
E william wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 44
Insgesamt: 594
