iPhone 6s Battery Drain.. can be caused From LSD?
Hi everyone.. HI @refectio SIR
I have an iphone 6s with battery drain problem. Obviously i replace tristar battery dock connector check without everything connect, for verify if the problem is in MOTherboard.
During Microscope check i verify LSD Damage, phone work perfectly but have only Battery Draning problem. Abybody think it can cause from LSD damage? Thanks Guys
Ist dies eine gute Frage?
2 Kommentare
That doesn't look like LSD damage to me. If you are uncertain, you can remove the standoff (it is soldered onto the board) and inspect it more closely.
von Minho
@refectio Thanks a lot Sir..
von AGS
