Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2265 Fragen Alle anzeigen
iPhone 7 Stuck On Apple LOGO
Hi Guys.. Hi @refectio SIR
I have an iphone 7 (NOT water Damage). When i connect it to DCPS, show 0,22 0,23 amp, and stuck on these values.
There is only apple logo on the screen.
Dont restart, just stuck on apple logo.
Check Audio IC, but no improve.
The phone doesn't HOT, there is no short on the board.
I found only long screw damage near the battery, unfortuanlly i did'nt find nothing on ZXW about LSD on phone 7.
If i try to reset have error 9.
Is there any suggestion  plz?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Try replacing tristar as it can cause stuck on apple logo. I’ve had one point where it would have no display but show 0.17A on the DCPS, then pointed to a shorted tristar (it heated up a pad under the PMIC):
https://www.youtube.com/watch?v=mcUgeDTt... at start if video pretty much same short I had.
War diese Antwort hilfreich?
Bewertung 2
My answer is replacing the battery. If you watch Hugh Jeffreys, you will know that he had the same problem with one of the iPhone 7 he was refurbishing. Your problem here is that your battery is dead and unable to charge. [Link removed]
After receiving the battery, find the right guide on ifixit.com and your iPhone will work!
Bewertung 1
2 Kommentare:
So it might be a battery replacement problem ???
von
I do a lot of fornite gaming on it. You think it might went bad i used it while charging all the time is that bad?
von
Thanks Everyone Guys.. its a Nand problem. I reball the Nand and phone turn on and work perfectly.. Thanks
Bewertung 0
Antwort hinzufügen
AGS wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 1,990
