Zum Hauptinhalt wechseln
Erschienen im Frühjahr 2014. Ausgestattet mit einem 5,5" Bildschirm. Ursprüngliches Betriebssystem war CyanogenMod 12S. Modellbezeichnung "ONE A0001"
110 Fragen Alle anzeigen
Are these parts necessary?
Hello, I am repairing my good old OPO, because of a broken display. I bought a new one with edge, because mine is completely broken. But there are parts in my old case, which aren’t in the new one (see in the pictures at the bottom the missing grid-foil, the missing black foil and the black foil in the place of the motherboard).
New case:
Old case:
Both (old one in the button, the new one above):
Are these foils necessary?
Edit:
Sorry if haven't point it out, but don't think of the stick tape. I made a new photo to show which parts i meant:
But thanks for this really fast response!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
The transparent blue are tape covers!
You carefully pull them off to expose the top side of the double stick tape surface to hold your ribbon cables going to the main logic board and the bottom tape holds the lower board in place.
The 3M logo’ed part is also a tape which holds your battery after you’ve put the back cover back on.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
[image|1775511]
von
Always carefully peel off anything u can that is missing on any phone or any device theres usually a reason for all of it…
Foil is usually to act like a heatsink/heat shield
Tape is usually to insulate or stop components touching other parts
Rubber gaskets and seals are for protection or covering speakers and microphones to eliminate other noise etc and around light sensors to stop light leaking in
P.s dont forget to transplant that earpiece speaker too and at the bottom of the pic there are I think 3 little things sticking out of holes I dont know what they are but stick them in too
Bewertung 0
Don’t worry about them.
Bewertung 0
Antwort hinzufügen
Moritz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 52
