Zum Hauptinhalt wechseln
The Ford Expedition is a full-size SUV assembled by the American automaker Ford Motor Company. Introduced as the four-door successor of the two-door Ford Bronco, the Expedition has remained in production since the 1997 model year; it is currently in its third model generation.
72 Fragen Alle anzeigen
Help with passenger wiper arm install
2010 Expedition - just replaced the wiper motor/linkage assembly - can’t get the passenger wiper arm to fit all the way onto the spline - causing it to spin even though the bolt is securely on. Does it require a tap or two with a rubber mallet. I’d hate to wack it and break something else!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
See where this mechanic is pressing the blade to get it off. That may be where to press to help get it back on:
https://www.youtube.com/watch?v=VomF4yqY...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks! - I'll give that a try again - no problem with the drivers side!
von
Antwort hinzufügen
Jeff Tkac wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 43
