Zum Hauptinhalt wechseln
Die Wi-Fi Version von Apples iPad 6, erschienen im März 2018. Erhältlich mit 32 und 128 GB Speicher. Ausgestattet mit einem 9,7" Retina Display und einem 64-bit A10 Fusion Prozessor.
151 Fragen Alle anzeigen
Soldering small touch connector
Has anybody replaced the small touch FPC connector on the iPad 6?
I noticed this style connector doesn’t have the legs protruding out wards but attaches directly underneath.
Any pointers?
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You’ll have to solder it back using hot air. This, of course, presents its own challenges ;>).
The trick to soldering plastic connectors with hot air is to:
  • insure the board is properly cleaned and the pads tinned
  • then pre-heat the area of the connector, apply some flux paste and align the connector so that the metal legs are sitting on the tinned pads.
  • then apply heat but not too close as you don’t want the air flow to blow the connector off the board
  • keep your eye on the plastic, if it starts melting then you are too close, too hot or the airflow is too high (this is the part that takes the most practice)
  • once the pre-tinned solder flows, the connector should fall into place…adjust it slightly with tweezers but don’t apply any pressure on the plastic itself as it is very soft at this point.
  • expect to go through a few connectors at first, the slightest mistake will cause the connector to melt or warp.
Good luck!
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
I thought as much
Thanks
von
If you found this answer helpful, please select "Was this answer helpful? - YES" and/or if this answer solved your problem, please “Choose as Solution”. This allows people in the future to understand which answers helped solve the problem and adds value to the site. - Thanks
von
Antwort hinzufügen
Lee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 6
Insgesamt: 106
