Zum Hauptinhalt wechseln
The HP Compaq 2510p, model number "GM651AW" and was released June 2007. It features an Intel Core 2 Duo ULV processor and 12.1 inch display.
4 Fragen Alle anzeigen
My laptop won’t charge.
My laptop won’t charge and displays a steady white light and a blinking yellow light on the charging led. Whenever I take out the battery it still won’t turn on. I even tried replacing my charger although I don’t know if the one I replaced it with is compatible with it although there the same brand. I need help on fixing this cause it’s not even my laptop but my sisters laptop and I have not told her it isn’t working as yet.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@romainedwyer check your AC adapter with a multimeter to make sure that you have the right voltage. The brand is irrelevant for as long as the specs are the same. For this laptop you will need a 65Watt 18.5V 3.5A power adapter. Let us know what you have.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Romaine dwyer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 181
