Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
Dropped iPhone 4, Touch Screen not working.
Hi
I dropped my iPhone 4 and now the touch screen is not working. I can see a hair line fracture in the panel behind the front glass panel. Everything else seems to be ok.
Please advise what parts would I need to replace?
Ist dies eine gute Frage?
Bewertung 6
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
Sounds like the digitizer has been broken. You will need the following part to repair your device.
iPhone 4 (GSM/AT&T) Screen
iPhone 4 (GSM/AT&T) Screen Bild
Produkt
$24.99
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
+ sure agree with that. The crack that is visible, probably destroyed the digitizer circuit...
von
If you have tried changing the touchscreen and still touch is not working, That means your phones touchscreen controller (IC) is faulty,
Bewertung 1
The digitizer connector has probaly become dislodged slightly I have fixed many by opening the back and reseating the digitgizer cable. This is much more common when someone has removed the emi shield from the back of the board.
Bewertung 0
Yup, you just need the digitizer. The LCD and digi come as one part so it should be an easy fix. If your not sure how to see youtube or get a pro to do it. You can buy the part here on this site or try other sites like;
digiexpress.com
ipodrefresh.com
rapidrepair.com
Bewertung 0
Will replacing the screen fix the problem of the semi responsive screen problem?
Bewertung 0
i dropped my iPhone 4, it fell, the fall formation preceded by the lower part and its near the iPhone speaker and the bottom part of the screen does not work and this is the only part that is not working
can you give me some tips to fix my phone with that problem of it.
Bewertung 0
Antwort hinzufügen
Anuj Mathur wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 17,002
