How to upgrade the ssd of asus G551J laptop from 128Gb to more
How to upgrade a half size 128GB M2 Sata SSD to a 256GB or more on an ASUS ROG G551J what I must dismount to access to the card ?
Ist dies eine gute Frage?
Hello there!
Replacing the mSata SSD on this model is not that easy as changing the SATA HDD, but you don’t have to be a rocket scientist - simply prepare to turn more than 5 screws.
Step 1: remove the battery
Step 2: remove the screw in the center and take out the optical drive
Step 3: remove the two screws from the bottom door and take it down.
Next, remove 3 screws holding the HDD, detach two cables and one screw for the Wi-Fi module and remove the RAM memory
And we’ve reached the halfway, some more screws ahead.
Step 4: remove 8 screws from the bottom case
Step 5: get some plastic opening tool (or an old credit card) to detach bottom case from the palmrest. Be gentle enough not to damage two cables between them.
1. Detach speaker cable from the MB
2. Detach screen cable from the MB
And here it is - remove the last screw and get the old mSata SSD out
Hope this helps you. Cheers!
War diese Antwort hilfreich?
Here’s a good video on doing it on your model:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 53
Insgesamt: 6,009
