Zum Hauptinhalt wechseln
2,6 GHz Dual-Core Intel Core i5 Prozessor (Turbo Boost bis zu 3,2 GHz) mit 3 MB geteiltem L3 Cache. Erschienen am 13. Februar 2013.
114 Fragen Alle anzeigen
New Battery Is Charging & Recognized, Won't Run on Battery
Just replaced the battery in the MacBook Pro 13” with a new one from iFixIt. The battery shows up at 78% and is charging, I’m watching the mAh increase. The LED on the charger shows orange, as in charging. If I disconnect the power supply the computer won’t run on the battery alone, it must be plugged in, even though it has a charge. Any ideas?
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
Lets get a better idea on what's happening. Install this gem of an App CoconutBattery Take a snapshot of the main window and post it here for us to see Bilder zu einer vorhandenen Frage hinzufügen
von
Thanks Dan, I uploaded that.
von
Well the battery does appear to be in good condition as you implied.
So that part of the circuit is working so if you now pulled the MagSafe connection he system would just shutdown on its own in a few seconds. Is that correct?
von
@danj Right, if you pull the MagSafe it powers off immediately. Battery has charged all the way up now thouhg.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Sadly, I think the switching logic which control the power source from the battery to the logic board is not working.
It’s going to take someone with deep circuit diagnosis and access to the needed schematics and replacement parts.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Greg Dietrich wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 92
