Zum Hauptinhalt wechseln
Vorgestellt am 16. September 2016. Modelle A1661, A1784 und A1785. Verfügbar mit 32, 128 oder 256 GB internem Speicher in den Farben Rose-Gold, Gold, Silber, Schwarz, Diamantschwarz und Rot.
1366 Fragen Alle anzeigen
iPhone 7 Plus stop charging at 3% after replacing new battery.
My iPhone 7 Plus battery just got replaced with the new one. I forgot to put ‘sticker’ to prevent the battery from moving. after few months the old battery stoped working, I even cannot charge it at all.
After that I replaced it with a new one. It stop charging at 3%.
I opened battery setting, it didnt show at all about battery capacity.
And then I also tried 3uTools, and I cant read the capacity too.
Anyone have a solution?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
There are some tiny components surrounding the battery connector. One of them allows the battery charge state to communicate with the CPU/Charge Circuit. It’s not uncommon to accidentally dislodge components when disconnecting the battery and this is a typical “pry damage” symptom.
Look for R2201 in the image below.
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
How should I fix this?
Are you suggesting me to buy a new dock connector replacement?
von
No, you need to determine if the highlighted component is still there. If it's missing, it must be replaced which would require a micro-soldering repair.
von
Hi, I didnt quite understand what is actually "battery connector". I looked at the battery connector on the flex cable and in the motherboard, on my eyes the diagram given is not matching with the one I see. SO maybe I looked at the wrong one
von
FYI: I got a replacement batt, now it charges only till 13%
and then it wont charge againt till it droped 1% and the phone restart by itself
von
Have you tried other new battery? maybe the battery you replaced was faulty.
Bewertung 0
2 Kommentare:
No, I havent. I will send it back to the seller today. I hope its the battery
von
Just try to test your old battery if that charge more than the percent you need, if that goes up means you got a faulty batt.
von
Antwort hinzufügen
Henka Gonzalez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 319
