Zum Hauptinhalt wechseln
The 2005 version of Volkswagen Beetle is the upgraded version of the 1998 edition, which obviously came with a large number of improvements and advanced features.
How do I get AUX input out of the body of the car?
The AUX input has been knocked inside the body on the inside of the car. Does anyone know how I can get it out?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
So if you fit the plug in it will toggle side to side or it goes in but you don't feel the detent?
von
Hi Dan, the AUX input used to be where that black hole is now. The input was pushed inside and I'm not sure how to get it out
von
We’re is the aux located ?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This YouTube video shows how to take the center dash off for the Volkswagen Beetle 1998-2010.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Hi Joshua, thanks for this. I'm not sure I'll be able to get to where the AUX cable is via the area where the centre dash is though
von
Ryan,
You are going to need to remove the center dash just to put the AUX port back in. Once you have the dash off, you can look and see where the port has fallen. This will provide you with more room to work with rather than trying to go in from the bottom.
von
It maybe cracked so the part is not secured or the socket maybe broken. The test I had offered to you would give you a clue which way things are likely to go.
If you can wiggle the plug side to side the socket is not mounted to the panel.
If you don't feel the detent (comparing to another device) then the socket has failed.
von
Dash is usually easy to get off .has screws or clips holding it in place. Check u tube for your car model and then replace jack and glue bk into place.
Bewertung 0
Antwort hinzufügen
Ryan Ball wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 95
Insgesamt: 8,886
