Zum Hauptinhalt wechseln
Released May 2012, identified by model number J2011-03-US.
LED Flashing red when plugged in.
When charging my Big Jambox the LED ring around the power button is pulsing red. It says 3/4 battery when I press the “J” button and is still connects to my bluetooth. I cannot understand if this is a problem or not I don’t remember it flashing red before.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your battery is failing! While it still may offer enough for the amount you are using the speaker the battery will need replacing soon.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thank you!
Any suggestions for a good replacement battery? I've found several on Amazon just not sure what I should be looking for.
von
Here's the guide to replace it Jawbone Big Jambox Akku tauschen As to who's battery I don't have any option on who's
von
Antwort hinzufügen
[deleted] wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 44
Insgesamt: 8,907
